I am building a pair of night stands with curved fronts – two drawers per stand. I have always set drawer bottom panels into the reverse of the drawer front by means of a groove. Easy to do on a straight piece but I am wondering how to do it into a curved front. My preference would be to use hand tools but will go the power route if necessary. Appreciate any and all guidance.
thanks in advance
Larry
Larry,
I tend to go the power route. I would use a slot cutting bit with a bearing set in a router/table.
Aaron
thanks aaron
Aaron,
thanks for the response. The slot cutter with a bearing is what I will use. I am still curious however as to how to do it with hand tools as more and more I am leaning toward them and away from machinery.
larry
I've never done it with hand tools, but it is possible. I just pulled a couple hand plane books off the sheld and Garrett Hack's The Hand Plane Book shows some cooper's tools starting on page 212 and he makes mention of a tool called a croze. Apparently, this was used to cut a shallow groove in the inside of a barrel in order to seat the lid. It's a pretty archaic tool, but you might be able to find something on the interweb.
Also, you might be able to accomplish the same thing by using a stanley 45/55 combo plane or simply putting a radius on the sole of a grooving plane and riding it against a fence.
Good Luck!
Aaron
another option
Another option would be to make your own grooving plane havig a curved bottom surface that matches the curve of the drawer front. The utility of such a plane, of course, depends on having drawers of a consistent curve.
Perhaps a scratch "bead"
Perhaps a scratch "bead" tool. A mortising gauge with twin cutting knives would speed the process initially by defining the borders. Of, with the borders defined with a mortising gauge, appropriate carving gouges could rough out the depth pretty quickly, but only if you are much more skilled with the gouges than I am.
panel groove
Ralph/Don,
Thanks for the suggestions. The dedicated groove plane would seem to be the best hand tool approach. I would mess things up I am sure if I tried to gouge approach.
Larry
panel groove
Aaron,
thanks for taking the time to research this. I will do some research of my own just to satisfy my curiosity but will go the power route as you suggested.
mortise gauge
If you can find a knife type rather than the pin type mortise marking gauge you can lay out the grove and slowly chisel out between the lines and reset the knives a bit deeper on the gauge and keep going down till you reach your desired depth.
Larry I know its been a while since you posted. Lee Valley sells a hand tool, Veritas Beading tool that might work for this. It holds a piece of scratch stock - your own or their standard profiles - and you pull it against the edge of your work piece like a plane. I've not used one, but seen it demoed. Might work but would take a long time.
EDIT oops, I see this tool was mentioned in earlier post
