I am a beginner at wood turning and have a question about the recommended length for a bowl gouge. I am also wondering what would be a good size gouge to buy for making bowls- 6″ in dia
Thanks Roger
Edited 4/23/2005 10:19 pm ET by Roger
Thanks Roger
I can't really say a good length for a bowl gouge but a 1/2" bowl gouge is a good all around size. Mine has worked very well for the 7" bowls I've made. The 5/8" size is also popular but better for larger more sweeping bowls.
--Rob
Thanks Rob,
I am looking at a 3/8 or 1/2. I only have a midi lathe and 6" bowls are as bigg as I can make.
Longer is better, leverage is key to control in bowl turning.
Thanks Napie,
I looked at some. It looks like 22" to 24" is the route to go.
Learn a thumbnail grind and keep it VERY sharp. You can use the edge straight from the grinder, no need for fancy diamond hones.
Thanks again Napie,
I am finding a noted difference between tools when I cut the wood for the bowl. If I use a small piece of a tree limb, with the end grain as the inside of the bowl I fins the scrapers do better. If I use the straight grain or face ( I think) then the gouges work okay. The problem I have is trying to use a spindle gouge on the hollowing out. They have 16" or shorter handles and I get a lot of catches. I will look at buying a bowl gouge and see if the different point and longer handle work better.
Roger,
End grain and faced grain are very different. A spindle gouge shoud never be used for face grain hollowing of a bowl, that's what a bowl gouge is for. The spindle gouge is fine for end grain "back cutting" however, but that takes a bit of practice. Catches are not a function of handle length, you have to keep the bevel rubbing or you'll snag the work every time.
Get the book "Turning Wood" by Richard Raffen, it's the best and his videos are very well done.
Edited 4/26/2005 4:57 pm ET by napie
Thanks Nape,
persimmon I come over for lessons? ( just kidding) I figured out the hard way about the different uses for gouges, after the bowl I was cutting jumped at me- twice! I stopped by and visited with the staff at a Woodcraft store in Peoria yesterday. They were very helpful and I found some classes I can attend. I did buy the book you mentioned. While in the Woodcraft store, I looked at the different gouges and plan on buying some bowl gouges. I also found that they had a good selection of spindle gouges that I like better than the one's that came with my Delta Midi Lathe.
The wood I am cutting is Persemin. It was from a tree just cut down. I have obtained a good stock of it, but I think I will start with some Maple I have have first.
Thanks again Roger
Roger, I'll suggest that you look around for a local turners club, they'll be a lot of help to you.
Ask around your local suppliers, they should have an idea of how to contact a club.
Thanks Leon,
I did, and visited my local Woodcraft store. Going to take some classes, join a club and practise , practise , practise.
Take care Roger
