Turned my first today. The exterior part went well.
The problem came when I reversed and tried to hollow
out the end grain. I know there is a mistake here I just
don’t know that it is. Help Please
Ken
What sort of problems did you run into?
Where do I staart. I shaped a goblet with ####fairly narrow stem. When I began to remove the
wood for the interior I couldn't get the gouge
to remove any material. Then the piecd broke off
in the stem. I really never removed any material
from the interior. Was it a mistake the green
douglas fir was oriented with the end grain at
the opening of the vessel?
Ken
Goblets are usually turned along the grain so that you're hollowing the endgrain. Some thoughts:I've used doug fir for lots of cabinets and other stuff. But I wouldn't turn anything other than large architectural stuff with it, if I were fortunate enough to have such a big lathe. Doug fir has thick bands of soft wood alternating with very hard bands of harder wood. It easily separates (splinters) at the interface between hard and soft. I sand doug fir edges with leather work gloves since I don't want to put another spear through the palm of my hand.Also, most doug fir is new growth with wide growth rings these days since we cut the old stuff asap for 2x4's (what a waste). A thin stem is likely to have only one hard band in it and the soft wood is truly soft. Not very good wood for a goblet.When turning stuff like this, I use a forstner bit in a drill chuck in the tail stock to drill the biggest possible hole down the middle to the depth I'm looking for. Then, I use a gouge to open up the rest of the bowl.And, you might want to leave the stem thick until the inside is hollowed and sanded, then thin it down. It would give more support for cutting and sanding the inside.
Your comments make a lot of sense. Thanks
very much. I guess my biggest mistake was not
drilling out.
Ken
