I’m making some amplifier cabinets out of 3/4″ pine. The cabinets are joined with box joints. I experienced tearout on several pieces. The tearout occured on the side of the work piece facing the fence. The dado in the fence matches the dado in the work piece. I was using an almost new Forrest Dado King. What might have caused this?
I was thinking I might not have had the work piece tight against the fence on the instances that tearout occured.
Use a backer board against the fence.
Boris
No, he is already using a backerboard.
You might be right about not holding it tight enough. You could try small hand clamps, the mechical advantage and the fact that the clamps don't get tired is a big help.
You could also gang up the pieces together, with a clamp, each one acting as a backer board for the next,
And finally if you are still getting tearout, lightly score the cut line across the grain with a razor, the line will then be sanded out when you make the joints flush. Justus Koshiol
Running Pug Construction
I re-read his post and I didn't see that he was using a backboard against the fence--only a fence. And, he says the fence dado and his finger joint dado match up. Of course they do.
He needs to get a piece of scrap and place it behind the piece for dadoing. AND, move the scrap, along with the piece, so that fresh backboard is behind the piece for each new cut. The last poster correctly stated that the backerboard must be tight.
That blowout is caused by the fact that "the fence dado and his finger joint dado match up."
There should be no blow out if a backerboard is used, and if there is, I would be astonished. This like using a backerboard for planing a door, on the exit side of the cut--it will always chip out, unless one has some scrap.
Boris
If you cut the slot in the fence with exactly the same dado thickness that you're using for the box joints, you should not be getting tearout. Is there any chance that one of the dado blades is in backwards? (Don't laugh, lots of us have been there!)
Would it be safe to ####ume that the thickness of the backer is not all that important?
For instance, could I use luan? It's cheap! BTW, I like the idea of ganging up the pieces. I'm trying to get more efficient. I will try it with two pieces clamped together next time I make a batch of these cabinets. Actually, I'll try it on some scrap material first.
no the thickness isn't that important, I'll often grab a piece of 1/4 ply and place that behind the workpiece, then just slide it down a notch to keep a fresh surface behind the cut.
Just as a side note, unless your not covering these boxes and you want the joints visible for effect, you might want to think about biscuts. I think it would save half the time needed to set up the finger joints, cut, then sand flush. I've also made boxes with four corner miters, with 3/4 stock there is no need for reinforcement.
Just a thought. Justus Koshiol
The exterior of these amp cabinets will probably not be covered. I'm going to have to spend a little time repairing them. Some folks want them covered in tolex, some want the wood exposed. Fortunately the the tearout isn't to bad. I don't think the repairs will be noticable to the untrained eye. It's just going to kill more time. These are going to become hand built tube amps. They need to look great. I don't want this to happen again! This is my first project for sale (part time hobby supporting venture at present). I want my customer to come back for more cabinets. I imagine folks who can make these are a dime a dozen.
good luck, I wish you well in your venture. Justus Koshiol
