Hi everyone
I have a 14 year old b&q table saw The belt gave up and I cannot find another anywhere The circumference is 255mm with 6 ridges Any help or suggestions would be much appreciated
B&q?
B&D maybe. I am assuming it is a toothed (cog) belt that fits a toothed gear at each axle? Can you confirm.
I assume John_C2 is in the Uk as B&Q is a DIY store
I've seen B&Q mentioned as the UK equivalent of Horrible Freight here in the US. Whether the comparison was favorable or not is kind of a non-issue I think.
You might have better luck with an industrial supply store like GRAINGER or the UK equivalent. In all likelihood the manufacturer of your table saw used an off-the-shelf belt and not a custom-made one.
With luck, you can find a supplier within driving distance so you can show them the old belt.
