I am building a desktop shelf for my office. It will be 15″x60″. It will be constructed of 3/4″ cherry cherry plywood with a 6″ deep compartments below the top for form storage. I plan to hang the shelf on the wall using brackets as support. The shelf will hold a printer telephone laptop and a few files on the top. The twelve lower pockets will hold 1 1/2 inches of forms in each pocket.
I am not sure how to design the brackets. I do not like the basic triangle wedge shape. I prefer the curved S shape. Are there any structual design rules for the shape of the bracket?
Any idea how large the bracket should be to support the shelf with everything on it?
Thanks in advance for any insights.
Jack
Barrister, Whatever design you decide on, use plywood or built up plies of solid wood . Without the alternating grains of plywood, solid wood will split and separate under load and inherent weakness of the grain structure.
I recently used plywood to make brackets which had been used as drawer sides on fine furniture.
Two of the brackets split in half after the shelf was loaded.
Turns out, the ply grains were all in the same direction.
The reason they(Ethan Allan) chose that type of ply, was the horizontaly oriented built plies up were fine as drawer sides AND,
their upper rails were rounded over which disguised the look of ply.
Steinmetz.
Barrister ,
There is no hard rule on bracket dimensions that I know of so it is really up to your eye and the design of the piece . If the shelf is 15" deep then the brackets would lend more support if they were close to the depth of the shelf . Sometimes you may not have room to make them equal width and length .
Another suggestion would be to run back rails behind the pockets and screw through them to fasten the piece to the wall . The brackets would then be simply for looks .
good luck dusty
You could consider a french cleat and forget about the brackets.
C.
Thank you all for your imput. I will make the brackets out of plywood and they will be almost as deep as the shelf. Thanks again
Jack
Barr,when detailing your plywood brackets,don't create a sharp deliniation at the inside corners. Always 'radious' the inside corners as that adds additional strengthThe same reasoning apply's to metal
Look at any router bit's shaft
If the transition from shaft to cutter was at a sharp juncture, that bit would develope a tiny crack and eventually fly apart and bury itself
god know's where. Steinmetz.
Edited 3/21/2006 6:06 pm ET by Steinmetz
I am radiusing (spelling?) the inside corner as well as both ends. Hopefully it willlook as nice as I think it will. But the mind always sees things perfect. Its the hands that aren't.
Thanks for the advice
Jack
