I have broken two 1/2-inch bandsaw blades recently. I use a Delta 28-560, 16-inch, 3-wheel saw. (Yeah, I know it’s a dog. But it was way cheap.)
I was resawing some 7-inch-wide red oak.
Any ideas why two high-quality blades went bust?
Thanks.
Thanks.
Three wheel saws are rough on bands because the blade passes around wheels with a very small radius. Some mfgrs specifically state that their bands are not recommended for 3-wheel saws. You could try backing off the tension some as long as the band doesn't flutter.
Pete
Some companies make a special blade just for 3 wheeled bandsaws. I believe the reason was that the blades need to be more flexible since the radious of the wheels is fairly small. I would do some research on the web trying to find someone who makes these blades. I would grab a copy of FWW and go to the web sites of the people advertising band saw blades.
Tom
Try using a 3/8" blade instead. 3-wheel saws, as mentioned, are murder on blades. What brand blade are you using?
both blades were Timberwolves. Supposedly one of the best blades. I had not thought about the small wheels flexing the blades too much. I am a great woodworker! I still have 10 fingers. Oops! Nine.
If you're using Timber Wolf blades, you need to be sure they are the PC series, and not the AS. Most likely, you do have the correct blade, but just to clarify. I would strongly suggest you call them and explain what saw you're using, and what you're trying to saw, ask their advice on which blade will survive the best. 1-800-234-7297
Interesting info in their literature "Two wheel machines, smaller than 14" wheels, using 1/8" to 3/4" blades will encounter 20% to 50% less blade life. You will encounter decreased blade life with any three wheel band saw even if the wheels are larger than 14"."
Two things that might help improve life. Lube the blade (PAM non-stick cooking spray, wiped on with a rag as you turn the wheel by hand - machine unplugged of course) and releasing the tension when you're done for the day.
Edited 4/3/2007 5:48 pm by forestgirl
They are good bands. However, Suffolk Machinery specifically does not warrantee them when used on 3-wheel saws.Pete
Too Thick
Try using a thinner backing blade like a .023" that is what i find works best on my three wheel saw.
I buy my blades from http://www.abetterblade.com and non have broken on me
