I have come across an interesting effect that I hope one of you might be able to identify for me.
The other day I brought home a sawn piece of Queensland Hoop Pine 6″ wide(http://www.intad.asn.au/materials/wd_hoop.asp) to use as a peg rail inside – it carves well and ages to a really nice amber colour.
The major saw marks were pretty much straight across the board. I don’t own a jointer or a planer (pay to have it done for projects – the tools are on the want list) so I had to dress this board by hand. I removed the saw marks and got to smooth timber, but even with a good continuous translucent shaving taken with a 4 1/2 there remained discolouration in the timber.
The colour was a purple/brown set of close arcs running roughly 45* across the wood, exactly as you would expect to see from a circular saw. I had to revert to a coarser set jack plane to get rid of them and had the workout I missed because it was raining outside, so they were pretty deep.
Given that the wood was already smooth, the only explanation I can see was that this is water staining from sawing green timber. What is the real answer?
Dave
I'm assuming this was a circular saw being used? Probably was getting dull and hot. The heat/steam probably penetrated a little.
PlaneWood
Could also be from the natural darkening of the wood under light, with the color going deeper where the surface was originally lower than the surrounding surface. Try leaving it in a bright location for a few days and see if it evens out.
