I’m working on some bookcases for my den, but having a bit of a challenge with the finishing. I seem to get small flecks in the finish- I can’t tell if it’s dust, or bubbles, but it’s all over the place. I’m using maple veneer plywood, sanded to 220 and wiped with tack cloth. I put down two coats of the poly using a 3″ foam brush and “preloading” as suggested in the article here http://www.taunton.com/finewoodworking/Then/011179116.pdf
When I look at the wet surface, though, there seem to be tiny bubbles that just hang around into the drying process. I have a plastic “finishing booth” set up, so it shouldn’t be a dust issue. Both application of the finish and the drying takes place in the booth. I’m finishing before final assembly, so each piece is horizontal when I’m finishing it. I applied two coats, then sanded with 320 and wiped with more tack cloth. Then I applied coats 3 and 4 , repeating the sand/tack cloth between. Problem is still there…
Any suggestions? Would thinning the Polyurethane with a bit of water help? (I’m using Verathane Polyurethane Semi-Satin finish, No. 2002) Any other ideas? I may not be able to correct the issue on the pieces I’ve already done (short of sanding them down), but I have plenty more pieces to finish, so fixing this problem is a big priority.
Thanks.
DJS
“Honey, will you please make some sawdust and track it across the carpet?”
“Yes, dear…”
You can add a little distilled water--try about 10%. Too much and the finish won't coalesce properly. The Rustoleum web site doesn't give any technical data on their Varathane waterborne finish so I don't know what the limit is, or if another solvent could be used.
How long is the finish taking to cure? Unless you have done lots of air scrubbing in your "finish room", there is always dust in the air. If it is taking a long time to dry either because of humidity, or low temperature, more of the dust can collect.
It doesn't sound like its the problem but using a tack cloth isn't such a good idea, a damp cloth is better. Tack rags generally are oily with substances that waterborne finishes don't like.
The shop is a nice 70 degrees (gotta love CA weather) and about 50% humidity. After 2 hours, the finish is plenty dry.
My "finish room": I cleaned up the shop, swept, vacuumed, and ran the Delta air filter. Then I built what amounts to a plastic tent over a workbench. Create a frame 2' x 4', laid the plastic over it, hanging down on all sides. then I raised the frame up over the bench. The effect is similar to being underneath a table with a table cloth.
I'll try adding a bit of water from the fridge filter (warmed to room temp, of course). The fourth coat seems to be a little better, but I've got a lot of this to do still.
Thanks. "Honey, will you please make some sawdust and track it across the carpet?"
"Yes, dear..."
It sounds as if you need to thin the finish. The can it came in should tell you what the thinner is and solvent is. Add the thinner to your finish. Adding 1 to 10 is a good way to start. You will need to sand out the bubbles and dust. Be careful when sanding! You do not want to sand too hard. Just a light sanding to remove the bumps. So, sand first, then thin varnish and apply.
In addition, a sponge is not really the best tool to apply varnish. Try a varnish brush. This Brush is good http://www.amazon.com/gp/product/B000FPAOIS/ref=pd_rvi_gw_1/103-4344129-2712650?%5Fencoding=UTF8&v=glance&n=228013.
The key really is that the brush be Tipped and flagged. You can get one at a good hardware store. Also, buy the solvent that Varathane has listed on the can. You will need it to clean the Brush
Good Luck :)
Rich
Another thought that has worked for me on a small piece finished with varathane. Actually it is how I finish a poly finish also. After lightly scuffing the last brushed coat and tacking with a wet rag (NOT a tack cloth), I did a final coat using Old Masters Wiping Varnish, a gelled wiping poly. The completely dried varathane will not react with the oil poly, and wiping varnish leaves a perfect top coat. Smooth as a babies butt. I get mine at the local True Value hardware store. Let me know what you think.
Hey, I checked out the brushes on your link hoping it would explain tipped & flagged. No luck, so my ignorance shows. This is the first time I've heard the term.
Thanks, Jerry
Tipped just means the brush is thick at the top then tapers to the tip of the brush. Flagged means the bristles are frayed at the tip. This allows the varnish (polyurethane) to spread smoothly and reduce brush marks. Together, they improves your ability to get a flat smooth surface.
Rich
Hey, thanks again. I'll give it a whirl.
Jerry"I tried to think of that but I couldn't"
I am no way near an expert in finishing, but I recently talked to a guy who is a very good painter and i asked him a similiar question about the bubbles in the poly. He said to sand it using wet/dry sandpaper start high (like 600-1000) and work your way down until the bubbles disappear. If 600 gets rid of the bubbles stop sanding at that grit and don't go any lower, be careful.
Also while mixing the poly DO NOT go up and down. Stick the stirrer in to the bottom and slowly mix until the two parts and mixed fully. Also tapping the side of the can, will get some bubbles out.
He also said foam brushes are the worst thing for poly because they make alot of bubbles due to their construction. Also use the best brush you are willing to buy the brush really makes a difference.
And the hardest part, take your time, this is my biggest problem .
Good Luck
Steve
Thanks to all for their suggestions. I just did the finishing on the next round of sub-assemblies. I diluted the poly by 10% with some filtered water, and I also sanded between every coat, not just between coats 3 & 4. That seems to have done the trick. I'm still using the foam brushes, and that doesn't seem to be a problem. I think the slightly thinner poly has a better chance to spread out once it hits the surface.
Thanks for the help.
-DJS"Honey, will you please make some sawdust and track it across the carpet?"
"Yes, dear..."
