I will soon be making a large dining room table (3″ x 60″ x 12′) from a figured, double live edge bubinga slab and have not worked with the species before. Does anyone have any tips on a reasonably durable finish that will take a few knocks and spills, without having to re-finish every five minutes. I particularly don’t want anything that has an artificial like shiny finish. Suggestions appreciated
s,
that is a serious slab of wood. are you working alone?
eef
Go with a lacquer - spraying is easier if you're set up for that - otherwise they do make a brushing lacquer.
Get a low luster sheen if you don't want shine.
SA
Thanks, can you recommend any particular brand?
I like Nitrocellous Lacquer - see who sells it locally - or contact Mohawk Finishing Products - they can UPS materials
Talk to the folks about thinners, fish eye flow out, and retarder -
SA
I live in the Turks & Caicos Islands and would almost certainly have to import, but thanks for the tip
I have lifting gear in my shop and two very large sons! The slab was actually cut down from 22' long!
I've finished Bubinga with
I've finished Bubinga with Waterlox with good results, it's also very durable.
I am guessing waterlox is the trade name, will look this up, thank you
waterlox bubinga
I am building a table with a top of Bubinga- 3' x6' x2"- Big top. I plan to finish with waterlox as you said in your note. I am concerned that with the curls and sap in the bubinga that it might be wise to first put on a very diluted rub on coat of shellac. I do this when finishing with cherry to get an even look to a waterlox finish. Do you think that is necessary??
How many coats did you use?? Any problems?
I look forward to your reply.
Bob Garon; phone 216-283-8888
In case it helps you
http://forums.finewoodworking.com/fine-woodworking-knots/finishing/maloof-finish-1
http://forums.finewoodworking.com/fine-woodworking-knots/general-discussion/how-do-you-your-bubinga
I've finished my coffee
I've finished my coffee table, bubinga with Danish oil. It holds up well against fluid spills and has a nice soft shine.
Not particularly scratch resistant, but very easy to touch up. (Done it once after about 5 years).
I like the warm look of Danish oil, but had no idea it was that durable... thanks
For something that size, I would strongly suggest some test panels with finishes you are considering. Much too large to refinish if you're not happy with the look, or find it's not as durable as you hoped.
Are you looking for something bulletproof and easier to apply and/or not crystal clear, or the best possible appearance and willing to treat very gently?
Do you have a preference for application method, and is spraying an option? Are you willing to wipe on a number of thin coats? Are you willing to provide a lot of "elbow grease" or is ease of application primary? How rough are the edges?
Thanks for your excellent suggestions, I certainly agree with you on test panels! I am semi retired so I don't mind how much elbow grease/time goes in, I do have spraying facilities as well. I had concerns initially because I heard that bubinga exudes gum pockets sometimes and I was concerned how this would affect the finish. I would like a finish that is durable over time, shows off the wood to good effect, just practical really as I have grand kids who have spilled things on other finished projects that were just tung oil and waxed finished and I had to start over.
I forget to mention the sides are pretty clean, but will need additional work. I was trying to submit a picture of the slab but cannot find a way of doing this on the forum?
Join the site called PhotoBucket -
upload + reduce the size of your photo to PhotoBucket-
Copy and paste the HTML code into the reply -
There are better explanations on this site by a poster with the user name Lataxe -
Hopefully others will expand the directions to help you
SA
It is easy to post a photo "as the original poster in a new thread". I'd suggest that the title make it evident that is related to this thread.
