I was just given a retirement gift of a few old Buck Bros chisels. Some dont have handles and all need to be lapped, ground and honed. This i can do, but I was wondering about the quality of the steel in these tools, any experience? Thanks, John D
I have one, only one, old Buck Bros. chisel. It's about a hundred years old, and belonged to my grandfather. It is the toughest piece of steel for carpentry applications that I have ever worked with. It borders on impossible to hand-hone it, it's so hard, but not the least bit brittle. And when you get it sharp, it's really sharp. and stays that way. In my estimation, you've been handed a treasure as far as chisels go.
Bruce
The High Desert Group LLC
Thanks for replying Bruce, I now have four: 1, 3/4, 1/2 and 1/4, all are mortising chisels with no side bevel. The person who gave them to me said that they were given to him by some one who baught out tools from school districts that were closing their shop departments. These apparently came from Maryland.
John,
I've got an old '50's era I'd guess, Buck Bros socket butt chisel that was my Dad's, it has real good steel in it. Also have a couple carving tools that I bought new in '71. They are less nicely finished, but still good metal, they all take and hold an edge very well. The butt chisel is trademarked on the back of the blade, while the gouges were only stamped on the handle, which I cut off for comfort.
Bruce, I see you live in Durango, me too. Small world, John
Ray, thanks also for replying. I will need to make some new handles for three out of four of these chisels. Some walnut pieces were included with them, so I might try using them for the handles. John
John,
If they are butt chisels, usually they have a leather washer on the striking end of the handle as a sort of shock absorber. If there is a shoe repair shop in your area, get a piece of half-sole leather from them. It'll be about 1/4-5/16" thick, just right for that purpose. turn a stud on the end of your handle, drill corresponding size hole in the leather , cut oversize O.D. , glue on, finish turning. Just like down town.
Thanks for the suggestions Ray, I will see what I can do...John
John
I have a number of old Bucks Bros. chisels, and all are excellent steel. Mine range from mortising to bench to paring to crankneck. I have other old chisels also, some better than others, but the BB are right up there with the best. Enjoy your present. Probably my prettiest chisel of all is a 1/8" BB paring chisel.
Alan
http://www.alanturnerfurnituremaker.com
John, I've been refurbishing Buck Brothers chisels for years.
Socket or tang they're worth pampering.
Unfortunately, some stubborn 'Crapsmen' in the past,
have worn the handles down and even mashed up
the metal sockets with constant hammering on the steel.
Mushrooming is the word. Usually, the 'Nub'of the handle
is still captured inside the socket
Some (but not all) of these abused chisels can be salvaged
I grind away any mushrooming, then,
using a slow speed electric drill, ream out the nub
with a 1/4" drill bit (All the while 'Wobbling' the bit)
Then using a Dremel grinder, I remove any metal
infringing on the inside of the taper
Before sharpening and final honing the edge,
I use a mill file to remove any high spots along the length
of the blade, then polish the whole blade
on a medium Scotchbrite Wheel
As far as I am concerned, for the work involved
and the minimum cost (Flea found)
They are a treasure to behold and to use.
I once was given the ornamentally turned
wood spindles from an old baby crib.
(They had repeatable matched turnings)
I cut each of them up into usable lengths and with my lathe,
turned the ends to fit many many chisels with matching handles.
I recently 'Glommed' a badly beaten up 1-1/2" socket chisel
whose socket was so brutalized, that I cut off the socket,
squared off and chamfered the end of the blade, then polished, sharpened and honed the edge The new plane iron is 5-1/2" long and tapered fore and aft in thickness also the width of the blade tapers slightly from the front to the rear 1/8"
Great for adjusting in a wedged wood plane.
Just looking for a suitable chunk of wood to make a good old plane with my new iron.
Steinmetz.
Edited 9/21/2004 11:02 pm ET by steinmetz
Edited 9/21/2004 11:11 pm ET by steinmetz
Steinmetz, Thanks for your suggestions. One of my chisels is badly rusted and the socket is as you describe, mushroomed. The others are in quite good shape, with no wood left behind in the sockets, and only needing to be cleaned up and resharpenned. One actually has a crudely made handle that seems to be firmly attached, made from walnut. I will try to refine it without removal. With all the positive responses I have received on these chisels, I am realizing that I was indeed given a very valuable and thoughtful retirement gift. Hmmm, I wonder if needing to make four chisel handles is sufficient justification to buy a new lathe...thanks again,
John, If the chisel with the crude handle is the socket type, all you need do, is hold the blade in your left hand and using a plastic hammer or a fat wood club in your right one, smack the socket's outside and it will pop out . No damage to chisel or handle. Stein.
When I learn how to take and enter photos, I'll show you a wood lathe I made using a 1/2" variable speed drill
It's mostly made of wood with a two foot hollow metal base
Stein.
Stein, I will look forward to seeing your home made lathe...thanks again for everyone's suggestions...John D
