I’ve been commissioned to build 16 feet of bookcases, built-in. Would you remove the base molding to get them flush to the wall or leave them on? I would remove them, but would appreciate your comment. Thanks
I'd say it's worth asking the client their preference if you want another opinion. Personally, I'd want the bookcases flush with the wall.
I agree. Just be sure to blend them in well if they do come together at some point(s).
The bookcase becomes part of the wall. The baseboard continues around the base of the bookcase.
What those guys said.
I design the base of the built in so that the old wall base goes on to the new built-in like they were always a unit.
Remove the moldings in full lengths if you can without cutting them. If the bookcase runs into a corner take the baseboards from both walls. This gives you the best chance of reassembly without running short of material. Save as much as you can including the mitered ends, it will be close.
I share the opinion that it's best to remove and, if possible, reuse the baseboards. Another benefit in doing so is that it may make it easier to plumb and attach the back of the bookcases if the walls behind them are not perfectly vertical.
