I could sure use some suggestions on a built-in book case I am starting to build for a customer. I am wanting to do something different in regards to finishing the finish for the project. Normally I build the things in place with all the components, trim, caulk, etc… Then brush paint the latex then the water based poly over this. I learned the hard way that paper products stick to latex without a clear finish over the paint. Maybe I should be using something besides the latex and water based poly, tips?
I just purchased a HVLP sprayer. The other question is if you are spraying how do you accomplish this prior to installing the pieces? I can spray the carcass and face frames prior to install but what do you do about caulking the parts like edges and various trim pieces while installing in the home? For instance, the edge of the cabinet to the wall. I like it to be tight and look like part of the house. The same with the book case partitions and the walls. I like to hide nail holes, etc…. If the piece is pre-sprayed in the shop and you install this how do you touch up all these areas and it flows together? There is a difference in appearance from spraying to brushing. Basically what is your technique?
Thanks!
Semper Fi
“To be young and a conservative, you have no heart”
“To be old and a liberal, you have no mind”
Winston Churchill
“Some people spend an entire lifetime wondering if they made a difference. The Marines don’t have that problem.”
PRESIDENT RONALD REAGAN, 1985
Jar,
I do as much work in the shop as possible, and as little as possible in the customer's home. It makes sense in many ways.
So, spraying an hvlp finish is a good choice. If you need to fit cabs on site, it's best to leave the outer edge proud, and at 45*, to be easily scribed as needed.touch up with brush as needed.
Unless you have a tight vacuum in your spray booth, you'll get trmendous bounceback when spraying a carcass, so it's best to spray the pieces on the flat.
Expert since 10 am.
You can't be too reliable with a tag line like that !!! :-)
Thanks for the tips......Semper Fi
"To be young and a conservative, you have no heart"
"To be old and a liberal, you have no mind"
Winston Churchill
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."PRESIDENT RONALD REAGAN, 1985
now that you've got hvlp, try a pigmented lacquer for a very durable finish, better than latex.Expert since 10 am.
