hope all to everyone is well…i have never posted a message before or have written into the magazine about a problem, but i am a fan of their “methods of work” and “Q&A” sections. i used to work in prop construction, so my knowledge of finishes are limited. i’m really stump on how to begin my next project…i am restoring the wooden case to a 1930ish mantle clock. while the works are being fixed, i would like to work on a burn mark on the front. it’s a veneered finish and i’m not sure of the clear coat finish, shellac or laquer?? i’m worry about applying a stripper, not having worked with them. can i just sand off the finish?? any imput will be so well received…thank you
to tell if its shellac, an easy test is to get some denatured alcohol and a q-tip.
Find an out of the way area and rub the alcohol saturated q-tip around. If turns color (not dirty) its shellac. Basically youve taken a bit of the shellac off. If its not a new color its probably varnish or laquer
Bill, follow the alcohol with a dab of lacquer thinner. If it softens, then it's lacquer.
If it's veneer, I'd be very careful sanding. Almost every time I've tried, I've gotten too deep and ended up replacing that side. "Orange" paint removers will remove most finishes, and is gentle to the wood. Be careful with any liquids on the wood, especially an old one. Mositure could make it check (crack). It's usually best to try a patch on the back first. Good Luck, Len (Len's Custom Woodworking)
As Bill said, test the finish with denatured alcohol (to test for shellac); if that produces no result, then test with lacquer thinner. If that produces no result, the methylene chloride is what you'll need. However, with that vintage piece, it's more likely to be one of the first 2. If it's very thin veneer, I'd steer away from methylene chloride if possible.
You might want to clean it first with turpentine, so you're working with the finish and no waxes or dirt that might be overlying it.
Can you tell if the burn went through the veneer? Hopefully not!
