I’m finishing a mirror with a scroll-cut top. The scroll cut is terribly burned. Sanding is almost not an option because of the compexity of the pattern. Is there any chemical subtance that would be able to remove the burn marks? Any suggestions?
vw
Never heard of a chemical substance to remove burn marks. Scrape them off with a sharp chisel, or buy some cloth-backed sandpaper and cut it into narrow strips to fit into tight corners. Buff it like you would shine shoes with a cloth.
