Anyone have any inputs on what glue I should use for making a butcher block counter top? I was thinking about using titebond II because of the waterproofing values but am unsure if it’s food safe. Also any suggestions on finish. I have used mineral oil on some cutting boards that I have made, and that seemed to work out ok, but this is a fairly large countertop and I want to make sure that it is properly protected. Any advice would be appreciated. charlie
You can use Titebond II. It is water resistant and non-toxic when fully cured.
The traditional treatment for cutting boards and butcher blocks is mineral oil or an mineral oil/paraffin mixture. The latter will last longer.
To make it, heat some mineral oil in a double boiler. "Shave" in some paraffin--a ratio of about 6-8 parts mineral oil to one part paraffin is fine. While still warm, apply it heavily to the surface. Let it set overnight and then do it again the next day. Finish off by lightly scraping off any excess and the buff with a soft cloth. Re-treat whenever the board looks dry.
Titebond II is water RESISTANT, while Titebond III is water PROOF.
Both are food safe when cured.
All that means is the it will withstand being used in a continuous totally submerged application. For a cutting board, it has no real advantage over a TYPE II water resistant adhesive.Howie.........
Agreed, that in this situation either would work. I responded as he was asking about waterproofing with titebond II. I was probably being a bit picky, as I am sure it was meant to be water resistant qualities. and it was for making a countertop, nut a cutting board.
1 - measure the board twice, 2 - cut it once, 3 - measure the space where it is supposed to go 4 - get a new board and go back to step 1
Edited 1/30/2006 5:59 pm ET by Ricks503
