There has been a bunch of recipes for renewing oils, but I have an old block with old oil in it.
Best methods to draw that out, or at least strip the surface… and still be safe?
-zen
-zen
Wow, nobody in 24 hrs?
-zen
Scrape and bleach it??
If you are talking about an endgrain butcher block that is soaked with animal and other fats and oils, you can not completely remove it. There used to be itinerant guys who went to butcher shops and had a saw to saw down about a 1/2" of the block top. This flattened it and removed the gunky part.Depending on how much you want to do, you can try using a cabinet scraper and/or a plane. It will be lots of work though.The treatment they then applied was a mixture of mineral oil and paraffin.Howie.........
Howie,
Thanks for the history I didnt know that and its interesting.
-zen
Zen, If you attach a W I D E flat base to your router's base, you can skim off an eigth or more to reflatten the block.
Of course, you will have to surround the block (temporarally)
with four "Screeds" attached level and 'Proud' of the sides,
to run the wide base on. ( Done this on wide wood stumps and slabs) Works!
Stein.
