I’m new to woodworking, last time I did any woodworking was in high school. My wife let me make a major purchase of equipment. It took me 6 mths of overtime to save for it. I’ll be making my first purchase of rough sawn lumber next week. There are two places to purchase the wood. One stores the wood in unheated barns, the other in a heated store room. My garage is unheated except when I work in it. Will there be a problem storing the wood from the heated warehouse in my unheated garage?
No problem. Just let it aclimate for a week or so before starting to use it. Go for the best grade you can find at the cheapest price.
The humidity inside the heated store is probably low, so the boards will probably expand in width a little when taken outside. Don't forget to take this expansion/contraction into account when making stuff. As far as I know, lumber reacts to changes in humidity, not temperature. But, in any closed environment, changing the temp will generally change the relative humidity.
PlaneWood by Mike_in_Katy
PlaneWood
I always suggest that customers stack and sticker any lumber once it is in their shops for at least a couple of weeks. We have wood shipped to us from all over the US and the relative humidity differences vary a great deal. As we are in Texas, out RH is typically much lower than say the Pacific Northwest and most of the northern states.
It is usually never a problem if the lumber has been in our shop for a little while, but I hate surprises and want the customer to always get the very best results. An ounce of prevention is always a good rule of thumb to me. I have received perfectly flat wood from Oregon that was kiln dried, but may have been in a warehouse environment for a period of months. This woods RH will be higher than it was when it left the kiln, and will sometimes want to move if care is not taken to let in equalize to the now drier environment.
Curly Woods
Figured Hardwood Lumber Sales
http://www.curlywoods.com
From your post, Michael...
"This woods RH will be higher than it was when it left the kiln, and will sometimes want to move if care is not taken to let in equalize to the now drier environment."
I think you actually mean the wood's MC (moisture content) will be higher.
Firewood, are you buying kiln dried stock, air dried stock, green stock?
You really need to know the awswer to this question before you write the check.
Lee
Lee Grindinger
Furniture Carver
Yes Lee thank you for the correction. Moisture content was what I meant :-) Michael Mastin
Curly Woods
I'm buying kiln-dried lumber. The millworks that stores their wood in barns has greater variety, but is 1hr each way from home. The other facility is in an industrial part. They specialize in hardwood flooring and millwork for windows and doors. They have a small selection of rough-sawn. If I need wood for a large project I guess the larger millworks is where I'll go. The supplier in the industrial park is 10mins away, and I guess I'll use them for quick projects.
