I’m looking for the correct clearance distance of a kitchen cabinet over a gas burning stove?
Help
Help
The stove literature installation instructions usually gives the clearances. If you don't ahve it look online at the Manufactures website. I don't know if there are local or state codes but there probabaly are. Chances are the Manufactures specs fall within those guidelines.
Many thanks..............Jim
30 " from the cooktop to flammable surface overhead .
36" CT ht
66" from floor to top of standard hood ,
leaves 24" under hood
Check the local codes to be sure
hope this helps
dusty
Thank you very much. As you suggested, I'll will check local code as well.
Jim
Jimmie
I think you really have to check range to range. Some of the commercial types that find their way into a lot of homes these days have higher clearance requirements or allow no wood cabinets above - typically get a range hood.
One Viking I looked at had a 42" requirement. Most manufacturers websites contain the installation guidelines for their products.
Good luck,
Frank
Thanks again Frank. Wii take it all into consideration before installing.
Jim
