I’m looking at options for my kitchen cabinets. Like most of us, I’d like to be able to save some money on them. I’m considering hiring a shop to build the carcasses and drawers, and then I would build, finish and install the face frames, and buy the doors and drawer fronts online. Does this seem like a worthwhile option? Has anyone used a source that they would recommend? Thanks much,
Neil
Neil,
I've been very pleased with Keystone wood products located in Lancaster. It was very cost effective to use them for one project where I just didn't want to monkey with the door fronts. Keystone did a great job and got the doors to me faster than promised.
The only nit I have--which will probably be true with any such supplier--is that they didn't match the wood as closely as I would have. I usually make a series of doors from matched boards. The doors I got from Keystone didn't. After staining and finishing, only I knew the difference, but hey, if you want to be a perfectionist you need to be perfect at it, eh?
http://www.keystonedoors.com
Thanks, i like the options they have and if i want, they're close enough that I can make a trip to Hershey and pick them up myself. Thanks for the recommendation. Any others?
I used Decore-Ative Specialties in Elk Grove, CA for the kitchen doors and drawer fronts for my new house. Their product selection is large and innovative. I ordered some doors in maple from their Southwest Collection that are excellent quality, first rate material, sized just as ordered, and were delived within two weeks without a hitch. I could not have made these doors any better or cheaper myself. Their sales staff were good to work with also.
Build the doors also...I built 3k worth of doors for about $500 and a $100 frame and panel bit set....(which I already had)
Bud
I think that building the carcasses and drawers is no more work than building the face frames, maybe less. I use 1/2 inch baltic birch plywood for all of it - its strong, stable and light-weight. You really only need a dado blade and sander to get it done.
Good luck.
TTF
I build cabinets and I'd advise you to build the carcasses, hell there easier then the faceframes and doors/drawers.
But, if you really don't want to, a guy over at Breaktime uses Scherrs http://www.scherrs.com/, and he has nothing but good to say about them.
Take a look
Doug
This is how I do it.
http://i31.photobucket.com/albums/c387/brian1520/usa.jpg
http://i31.photobucket.com/albums/c387/brian1520/usa1.jpg
If you go with this plan, have the shop do the faceframes too. Then, it's their job to make sure everything is dead-on (straight, square, etc.)
If you have the skills to make the doors and drawer fronts, go for it but remember that their appearance is 95% (or more) of the overall "look" of a set of cabinets. Nobody ever "sees" the carcasses but one slightly out of square door shows up from across the street - lol.
Another potential issue would be the "guarantee" by the cabinet shop. I built a kitchen cabinet for a customer earlier this year and delivered it to their home for painting. When they called me back for installation (three weeks later), it was a major nightmare. The cabinet had been moved several times, dropped at least once, and had been used as a workbench during some other work. It took all day to do a two hour installation and the homeowner and I had to have a "frank and open" discussion about the additional installation charges.
