Hi Peter looking forward to attending your class in Atlanta next month.
I’m building a display Cabinet for our local Historical Society, They have a low budget and I”m trying to help. They want it to look like walnut to go along with other furniture they have. I’m thinking of using maple and staining it to look like walnut. Is there a better wood to use or should I bite the bullet and buy walnut.
For archival reasons what type of stain and finish would you recommend and how long should it cure before being used. They may be displaying anything papers and metal objects in the cabinet.
Don
outyonder,
I'm looking forward to it too. The Georgia Woodworkers Guild is certainly a class act and have been great to work with.
By the time you get done trying to match maple to the walnut you'll wish you used walnut. If you were looking for a substitute, mahogany would serve you well. Another would be Red Gum, long used by furniture manufacturers to simulate walnut. It is a porous wood and has similar grain patterns.
When I match colors, I always reach for dyes. Their clarity and transparency are unmatched by a stain alone. Personally, I prefer water dyes. Just be sure and raise the grain and sand it before applying a water dye. You can follow this with a stain if you'd like to deepen the color and also develop the pores.
For a finish I would recommend shellac. It's easy to apply and will cure in a relatively short time. Stay away from an oil finish as it will smell for a long time if the cabinet is enclosed. Does this cabinet have doors or is it open?
If you can show me a picture of the color you are trying to match on March 3rd I'll see if we can come up with a plan.
See you soon,
Peter
Thank you for your responce, yes the display cabinet will have doors to keep people from handling the objects inside.
I'll use shellac for the finish.
I will look a my qoute again an see if I can use walnut instead of going through labor cost of trying to make some other wood look like walnut. As some one said "bite the bullet and buy walnut."
thank you
Don
