Hi All,
I’m building a display cabinet for which the customer wants interior lighting..basically three small lights on the inside of the top of the cabinet.
I’ve seen the halogen lights, the 12 volt inner cabinetry lights, etc. but have never used any of them.
I want something that will create a decent amount of light but not a lot of heat. I’d like easy installation and to spend $50 or less on the lights.
Any folks with experience?
Please share!
Thanks, as always!
lp
Larry-
You might want to consider Xenon lights; much like halogen, but longer bulb life and less heat. Here are two sources:
http://www.brandlighting.com/xenon_task_lights.html
http://www.lightinguniverse.com/products/view.aspx?family=147697
Good luck.
Craig
Thanks Craig. I'll check out both resources.
Larry
About a year ago, I made a set of cabinets and used rope lighting. It gives off a soft accent light and stays cool even after being on for several hours.
