hello to all. i am at the point where i have need of a scraper. i know there are many out there but thought it would be wise to look for opinions. any info or suggestions would be most helpful. i have two cherry tops @2ft.x4ft. to clean up. many thanks bob
I bought the $18 set of cabinet scrapers from Lee Valley- They work great-
I use the Two Cherries, and they work fine. I wonder if Lie-Nielsen still has scrapers? Guarentee they would be great if they do.
If you have an old beat up panel crosscut, rip saw,back saw,ect, you can make your own scrapers from the metal blades. Using a hard tool (I use tungsten carbide scratch awl) scribe several times into the blade surface to form a scratch. Clamp near the scratch and you can snap the blade on this scribed line. Once you have the shape you like, sharpen using conventional methods. I have several shapes and use a Foredom/Dremel type grider to form concave and convex shapes to make scratch stock shapes. I can't tell any difference between these scrapers and comercially available ones. The one excep[tion is advertised higher Rockwell hardness scrapers that are avaialbe on the market. I only use these for hardened glue removal. The high Rockwells don't flex like regular scrapers.
