Hi Everyone– I have a question for anyone who has re-finished or re-furbished cabinets. Here we go:
The previous owner of our house did some quick fixes before selling. One of them was slapping a bunch of latex paint over the kitchen cabinets– without bothering to do things like– say– remove Scotch tape stuck to the surface.
They also painted over all of the hardware– and the hinges are a tarnished brass 3/8″ inset hinge.
Let’s start with hinges. If I want to replace the existing hinges– But I can’t find an EXACT hole/geometry match because the hinges are just a little different here and there– Should I:
1) Search old and reproduction places in hopes of finding an exact match so I don’t have to re-drill?
2) Give up on finding exact hinges and put new hinges all around– (What do I do with the older holes to fill? Is there a filler which can be drilled? We’re talking eighths of inches in differences here and there — Or should I move the hinge up or down 1/4″ (drilling new holes)?
Next problem– How do you hang doors on existing cabinets and get everything to line up perfectly? The cabinets are still mounted on the walls– What are your tricks for aligning doors if I’m using all new hinges?
Seeking a professional result from a patient amatuer.
filling holes
I glue toothpicks in the old holes. Let the glue dry and then cut flush with the surface. Accurate measurements on the cabinet and doors is required to get perfect alignment. Use an awl or small pilot bit to start new screw holes. Really accurate alignment is not easy with 3/8 lip hinges. Colored putty helps conceal old holes.
Good Luck !
Steve
what about ..
Like the other poster suggested you could use the toothpic and I've done it before. Putty is iffy at best. How about taking the time to remove the latex paint. Since it's new paint it should come off with a bit of elbow greese. Seems that is the least labour intensive. Post a pic of the cabinet and you might get some other suggestions. All kinds of ways to mount doors. Unless you really want to change it up, I'd get the paint off and just remount the doors.
