Blessings, Jim Graham |
Jim ,
The commercial installs I have done with metal studs were not like iron more of a thinnish metal , I use self tapping construction screws same as I use for wood studs .
I thought I had to use sheet metal screws but you are better off with a coarse thread if the studs are thin walled imo.
On some portions of the walls like around the window openings there was a border of thicker and harder metal that required a pilot hole then the same coarse screws .
hope this helps dusty
what dusty said.
Also I'd hang your cabs on a french cleat-makes it easier.
Expert since 10 am.
Jim-
Try this product http://www.danback.com/
We specify this on all our commercial projects- hope this helps.
edit... sorry I did not originally note in your message that this is old construction. My recommendation would obviously be for new construction .
Edited 8/2/2007 1:03 pm ET by jimstock1
If you need to do trim work and own 15 gauge angled finish nailer, Senco makes heat treated-case hardened finish nails for steel studs. They have two lengths available. 1 1/2" (DA17AIA) and 1 3/4" (DA19AIA). More likely you will have to special order these nails through a Senco dealer in your area as these are not commonly stocked by dealers. Also make sure you have a powerful 15 gauge finish nailer. Some of the light duty ones they sell at Lowe's won't have the power you need. A good Senco model that will have the power is either an old SFN40 or the current version of that tool, a FinishPro42XP.
