I guess I would like to see how things are going relative to the up-coming election.
Could I sign up for one month, then have it automaticly stop?
thanks KN.
thanks KN.
You're in. Send an email to [email protected] if you want your access canceled.
Are you sure that you did everything? I can't find it anywhere.
Sometimes it takes up to two hours to take effect. Check back in a little bit and let me know if you're still not seeing the folder.
Five hours and no access. K
I just checked for the third time and you do have access. Are you sure you don't see a folder on the left called "Woodworkers Cafe"?
Maybe you need to reset your cache. If you're using IE go to "Internet Options" under the Tools menu. Click on the options: "Delete Files" and "Clear History"
I am using Safari, and have emptied the cache, and it is still not there. Any other ideas?
What is the cafe?Thanks!regards,wyo (new FFW.com member)
The Cafe is an Opt-In folder in Knots for non-woodworking conversation. It shows up in the left column if you request access. I'll set you up with access. Reply if you'd like it removed.
Matt BergerFine Woodworking
Thanks Matt!
Matt, Could I get access to the cafe?
All Set.
Access please? Thanx in advance...
