Hi: What do I need to do to get into the cafe area?
Thanks, Yogi
Thanks, Yogi
You're all set Yogi.
Anyone else who want's access can post to this thread.
Matt Berger
Fine Woodworking
Hi Matt,Would you please set me up for Cafe access?Thanks,
Glen
Matt,
What is the Cafe and why do we need to request access to it?
-Chuck
Chuck,
The Cafe is an off-topic folder in Knots where most things go (not anything, but most things). To access it, you have to opt-in.
I set you up with access. Let me know if that's a problem.
Matt BergerFine Woodworking
Access please.
Access please. TWG
Access please.Billy Gear
All of the above should now have access.
Access Please.
All of the above are set.Matt Berger
Fine Woodworking
My turn please. PMMATTY. Thank you
Access please.
access please
access please,
Pedro
I also would like access to the cafe.
all set. enjoy.
Access, please.Frosty
Ditto please
Shawn
Access please.
Cafe access, please, Matt?
BruceR
Cafe access , please
Thanks, Paul
Access please and thank you.
Cafe access, please.
Thanks!
-Jerry
all of the above are set.
Cafe access, please.Arlington, Texas (The dash in Dallas-Fort Worth)
Practice...'till you can do it right the first time.
Please set me up for Cafe access.
rssteve
all set!
Please sign me up for cafe access also.
Peter
all set.
While you're at it, could you do me too, please.Rob
all of the above are set up.
I'd like to check it out. Thanks in advance.
all set.
Ok. Call me stupid. How do I find the Cafe?
It will show up as a folder in the left colum: "woodworkers cafe." Sometimes it takes a half hour to show up after your access is set up. Write back if it still doesn't work...
Ahh thank you. I will wait and let you know how it goes.
Please sign me up for Cafe Acess,
Alan Goldberg
Thought I had access, but guess not. Sign me up please.
Jim McDonald
Sign me up too please.
Thanks, Rob
Cafe Access please,
KWL
access to cafe please
cafe acess please
thank you mark
Sign me up as well if you could
Thanx
Coach B
Please set me up for cafe access as well, Chris
please set me up also
Scott
room for one more?
Sign me up please!
all of the above are set. I'm going home for the day so I'll check back tomorrow to see if there are more requests.
Matt Berger
Hi Matt:
Please give me acsess as well.
Bill
Please sign me up for Cafe Access.
Matt,
I asked you to sign me up from my computer at work and it worked, now I'm at home and don't have access. Do you need to sign me up on this computer? If so please do. Thanks a lot.
Rob
Please include me in the stampede to the cafe!Regards,Hastings
Matt, I too would like access to the prestigious Cafe.
Matt
If I can drink beer while i am there sign me up please.
thanks in advance
Thank you for setting me up. Where will I find it?
I'll take a stab at it. Sign me up, if you please. Thanks.
Dan
Steve
Matt:I know you explained this earlier in the thread, but I an unable to find the folder for the woodworkers cafe. I believe you permitted access couple of days ago.I feel really stupid. I have tried a different browser, since Safari sometines does funny things but I still cannot see that folder. Also reset the cache.Would appreciate your help.Thank you,Hastings
Do you know how to search for a thread by number? If so, try searching for #35566.1. It's a new thread in the cafe and it should get you there. Once you find it, you should be able to see where it is and get back there.
Mike HennessyPittsburgh, PA
Mike:I entered that message number into the advanced search field. The search result says that discussion does not exist.Maybe, there is a problem with my access? Hopefully, Matt will see this and have some ideas.Anyway, thank you for trying.Regards,Hastings
For some reason, the software won't allow you to enter the thread number in the normal search field. You need to scroll all the way down to the bottom of the search screen and enter it in the special box reserved just for entering thread numbers. While you're searching, search for directions on how to use this forum!
Just kidding -- you won't find 'em, 'cause there aren't any. Go figger.
Hi Mike:
I just double checked and your access to the Cafe looks good. I reset it just in case. Let me know if you're still having problems and I'll get the techies involved.
Matt
Matt:I am completely and utterly flummoxed!I presume the woodworkers cafe shows up as a folder with a brown bar, similar to "General Discussion" and all the other major topic folders.If my supposition is correct, then no such folder is showing up!Yours, very baffled.Hastings
There are, I believe, 16 topics (brown bars). Make sure you can see them all. For the first few months, I never noticed that not all of them always show up until you read through whatever shows up first. Try going to the bottom of the page, mark the page read, and go to the "Next 50" until you get to the end. See if it doesn't show up on one of the "next 50" pages.
That said, you ain't missin' much. You may even regret your decision to join! ;-)
Mike:Thank you for sticking with me!Well I tried that but no luck. However, I tried it in Firefox and the cafe finally showed up! I don't want to reset Safari, which I suspect might do the trick.Hastings
Acess please, thankyou
Please set me up for cafe access.
Sign me up too
P.S. If you don't see the folder "Woodworker's Cafe" in the left column try emptying the cache in your browser.
And me also (2nd request)
Could you set me up as well, please?
Please sign me up for access
all set.
I'm getting hungry, please give me access to the "cafe"
Bruce
Could you add me too, please?Thanks"Light the lamp, not the rat! Light the lamp, not the rat!!"
Rizzo the Rat, A Muppet Christmas Carol
Please set me up for Cafe Acess.
Jim
Cafe pleaes
Chardo
