In this month’s issue of FWW Tools and Shops on page 92 is a procedure for getting a crosscut sled fence perfectly square.
You take a roughly 18″ X 24″ board and label the edges 1 through 4. Then put edge 1 against the fence, trim edge 2, then put edge 2 against the fence and trim edge 3, and so on around, until edge 1 is back against the fence. Then rip about a quarter inch slice off edge 2 and label one end A and the other B. Snap the slice in half and compare the thickness of end A to end B. Any difference means the fence is not exactly square.
I can get A and B pretty close but I seem to be unable to get less than .016″ difference. That’s with edge 2 being the 24″ dimension.
My question is, should I be striving to get less than .016″ or am I being a bit anal? When I hold an eight inch Soreby try square against the corners and look at a light I see virtually no light.
Chris
So, how then do you attach the runners for the sled? it seems to me that this is where most of the slop comes from - getting the runners and fence straight on to the sled.
I spent an hour yesterday making a sled for my portable TS. Oak runners, sanded with 180, glued the first one to the bottom of the sled using a framing square, then glued the other in place (for the proper spacing). When I was all done, realized that the sled was too thick, and blade wouldn't cut through my 3/4" material at a 45 degree angle. Oh well...
Actually, I am not using a sled. So as not to muddy the water, I deliberately left out the fact that I am using a very neat sliding cast iron table on my Dewalt hybrid saw. The mitre gage (an Osbourn knockoff) has an eccentric screw for micro fence adjustment.
I seem to be toggeling either side of perfect by .015 to .016 or thereabouts.
Chris
ChrisB,
I've found that a piece of blue masking tape can sometimes be used to get a more accurate cut. It's a matter of trial and error to get the placement.
Rod
