Bowl
Looking good - just in time to put by the front door filled with Halloween candy - What's the size ?
SA
Thx, 8" dia x 5" high.
Bowl
Hey Willie -
The photo makes it look much larger - but I see your lathe probably handles about 11 inches inside ? Mine is that way except for the well which will handle about 14 in. - I like the way the sap wood seems to have been placed in quadrants - nice when it works out that way. Did you turn it green ?
SA
Turned the blank green about 5/8" thick and let it sit for a few months until dry, then did the final turning.
My Grizzly G1495 is about 10 years old and 10 - 11" for bowl turning is about what it can handle. I have done an 18" bowl outboard though, it's a bit shakey but taking small cuts it's doable. If I reinforce the cabinet it will handle that better. The lathe has never missed a beat, but by today's standards it is probably a bit outdated.
Oooooh La La !
That is one beautiful bowl !
Really nice shape to. I wouldn't know where to begin to pick a shape for a given piece of wood like this so that it brings out the best in the characteristics of the particular wood.
Obviously you got what it takes.
Thx for the complements. I never know what a bowl is going to look like and once the turning starts I just wing it until the shape gets towards something I like.
re: winging it
Winging it turned out well for you, Willie. The bowl looks great.
I've done a couple of lamps like that, back when I had a source for large cross-section (4-6") highly-figured walnut pieces in the 18" to 24" length range. Alas, I can't find a new source for similar stock now.
I used to TRY to cook like that
Then I finally learned what a bad Idea that is, me trying to cook that way I mean.
I suspect bowl turning might turn out the same way for ME.
It is really cool to see YOUR bowls though.
Beautiful work!
juniper (and yellow cedar)
I located some juniper logs (2, pieces, 7" X 30", plus the short one next to the finished piece) dead fall and turned onerudimentary vase. I had trouble with voids, knots and bark inclusions tearing so I used a scraper to refine the outer protions
I tried a finish I liked (nitrocellulose) but sanded it off and refined the shape. What finish did you use?
I also wanted some advise about turning the cypress (yellow cedar) knot blanks a friend gave me. The square one has a number of fine cracks so may need work using that turners glue to hold it together
I used four coats of Deft gloss lacquer, followed by a light rub using a 3M automotive compound.
Stabilize the knots with CA glue before turning and if some start frailing during turning, stabilize them again.
