I have a maple dresseer w/ lots of detail, nooks and crannies, I am thinking this will minimie runs, blotching ect, all thought appreciated, Dave
For years, spraying was my exclusive method of applying dye stains. I held the gun (HVLP) in one hand and a wipe rag in the other. Otherwise, you will get too much dye on areas and not enough in others (wipe-on, wipe off method). Plus, spraying is pretty much always the most productive method of applying finishes anyway.
I used the alcohol-based stains from Mohawk and occasionally mixed waterborne anilines with them. I often would reduce the dye stains with alcohol, that way I could apply multiple coats or heavier applications to help control the color intensity. With straight mixes, you can apply too dark and can't do anything 'bout it. - JB
"The furniture designer is an architect." - Maurice DuFrenes (French Art Deco furniture designer, contemporary of Ruhlmann)
http://www.pbase.com/dr_dichro http://www.johnblazydesigns.com
Not what you asked, but a variant...
I like to spray water on the wood and then brush in the water based dye, and wipe. That way I can brush more to darken it as the water dries, or spray on more water to keep it light. I love the control. Just use an ordinary water bottle with a spray top, like used with cleaning supplies. If I am trying to hide some sapwood, etc., I sometimes use q-tips to put on an intentionally uneven dye, following lines like wood grain.
________________________
Charlie Plesums Austin, Texas
http://www.plesums.com/wood
