Can I Use 1″, 4 Tooth Spur Center to Turn Large Logs
Hi all,
Good to be here. I am new to woodturning and recently purchased a Powermatic 3520C lathe. I bought it to turn large, green logs for my business. For the most part, I’ll be making very large candle holders. Can I use the stock 1″, 4 tooth spur center to turn logs as heavy as 70 pounds?
Any information is greatly appreciated.
-Jared
You can try it but its very likely to spin free as you start removing wood. You will get a better grab with a screw chuck backed with a face plate .
That's what I'll do then. Thanks Gulfstar.
