I plan to make a candlestand which will not be tilt-top, and I wonder how I will have to assemble the top to the leg. The top will have approximatly 16 in, and the leg will be 3 in. in diameter.
Betula,
Cut a disk 6" to 8" in diameter and drill a 1" hole in the center. Cut a tenon on the top of the leg to match the 1" hole. Glue the disk to the leg. Screw the disk to the table top.
Bill Arnold - Custom Woodcrafting
Click Here if you're interested in a good,inexpensive website host.
you could also cut a kerf in the tenon and add a wedge for a really tight joint. Art
Betula,
What you see most often on old work is a batten about 3-6" wide and 3/4-1" thick at the center, chamfered on its edges and/or tapered in thickness towards each end, to 1/2" or thereabouts. Turn (easier) a round tenon on the end of the shaft, or saw (better in my opinion) a square tenon. Through mortise the batten, and glue and wedge the tenon in place. Screw the batten cross grain to the underside of the top, to prevent warpage,making allowance for seasonal movement.
I like to orient the batten so that the grain of the top, when attached, is at a right angle to one of the legs, if this is a tripod table. The top will look "funny" if the grain is running at some random angle to the legs of the base.
Good idea! Thank you!
You're welcome, and good luck on your project.
