Any thoughts or info sources on what type wood and what wood shape/size is best for a canopy bed ‘s top rails?
To prevent sag of the board/and to keep it straight.
Edited 10/18/2006 2:05 pm ET by edwardh1
Edward,
The flat canopy frame on my queen size bed measures 1 3/4"w x 1" th . Two stretchers measure 1 1/2" x 1". Walnut. Hasn't sagged yet, after 15 yrs or so.
I usually make the frame from the same wood as the bed. One of the shops I worked at used poplar, stained to match, for all their frames, same as they used for the beds' side rails. Most any hardwood will be suitable. Mostly folks nowadays want a lightweight fabric or fishnet material for a canopy. Beds with heavy drapery type canopies will need correspondingly stouter frames, which can be covered with fabric, like a window's valence. Some of the old canopy frames were quite substantial, with pulleys and drawcords inside to open and close the drapery.
In dressing stock for the frame, sometimes it will develop a bow as it rests. If it does, just work the piece so it ends up on the bed with its bow up.
Ray Pine
I made a single canopy bed maybe 15 years ago for my daughter, I used 1x2 Poplar half lapping the ends for the canopy rails, the bed is up again in our guest room, no problems with sagging.
