HELP! I’m in the middle of a project for a client and I can’t get a good edge out of my jointer to glue us some raised panels with. I have a delta 6″ benchtop unit (yeah I know I should have gotten a better unit but it’s what I have and I can’t swing another just yet)
Anyway I’ve tried and tried to tweak it but no matter what I still am getting a very slight curve to the pieces. when I place them together I have about a 1/64 gap in the middle. enough to let light through and not give me a good fit. the panels are to be glued up from 1×8 poplar pieces that are 17″ long.
Is there another way to get the edges clean to give a good glue up? I have my router table and have thought about using that as I have to get this done. I’m running behind on this job because of all of this futzing around with the jointer.
Even trying to squeeze them together with the clamps isn’t working as the boards are too wide and short to get any spring out of them.
Thanks for any help or suggestions you all may have.
Steve
S.J.MERRETTE Carpentry & Construction • Robesonia, PA
Nothing is impossible…It just hasn’t been done yet.
steve;you have a good jointer ,don't be down hearted; you just don't have a long enough out feed platform to keep your wood from moving wrong when you take it through the jointer ;
solution;get some 3/4" M D F board and build you a infeed and out feed table or just cut a rectangle in the middle of what is comfortable for you to work over and make sure it is flat and parrell to the top of jointer. wax it heavy with good paste wax 2-3 times and buff it out , you will see a great difference in you boards
Hey Steve
I have the same jointer. It's a good tool. Like WOODWOMAL said, it needs more outfeed and infeed table if you are doing a longer piece. I made mine out of melamine .
Stan
I have finally tweaked it to be a good joint but not without alot of heartache. Some of you mentioned building infeed and outfeed tables for it. I can see a fixed outfeed table as that is stationary but how would you suggest the infeed so that it travels with the jointer's infeed table? I would obviously prefer something that doesn't take alot of figdeting with to get it dead nuts with the machine's infeed whenever I make adjustments to the cut. Thanks for the previous replies please keep them coming.Steve
Nothing is impossible...It just hasn't been done yet.
Steve,
Edited 7/6/2002 2:29:08 PM ET by J Fusco
Edited 7/6/2002 2:29:30 PM ET by J Fusco
Joe. sprung as I take it means you can clamp it tight. this is on the edge of 17" long 1x8 poplar. by the time I could apply enough pressure to draw that joint tight I would crush the outer edges of the boards. (I know I already tried) :(Steve
Steve about time where you been..Jointing poplar I guess :). Hows the wife and your baby doing. I bet he's up and running all over the place by now.
I had the same jointer. I have planed boards 4" wide and about 6' long with it. I didnt need a infeed table and used a roller stand for the outfeed. I also got that effect from the TS not hoding the wood tight to the fence I suspect. Do you use a grip tight or feather board when you rip the wood on the TS ? Darkworksite4: When the job is to small for everyone else, Its just about right for me"
Edited 7/6/2002 2:55:46 PM ET by Ron Teti
Steve,
Edited 7/6/2002 4:52:06 PM ET by J Fusco
You got it Joe. Maybe I should be using pipe clamps instead of the ones with a bar. they seem to spring too much and pop things out of the clamp as you tighten.Steve
Steve,
Joe nice info. I've glued up lots of panels before, my gripe was getting that galdarned jointer setup. I was trying to use some whimpy quickgrip clamps and couldn't get enough pressure. I said phooey (well actually I said something else but the word police would flag me on it here) anyway I went back to my trusty 3/4" pipe clamps and those panels are looking mighty sweet now. but hey thanks for you input and interest. If you care I'll send you some digital photos of the finished project when I'm done.Steve
Joe I do a very simular method except once I tighten the k-bodys I wait a few minutes oh about 5 or so then wipe the glue with a wet rag then I loosen the K bodys turn the boards over and wipe the glue on the other side then retighten. I have a lot less sanding to do then. Darkworksite4: When the job is to small for everyone else, Its just about right for me"
Ron,
Edited 7/7/2002 8:59:22 AM ET by J Fusco
Steve,
Just a note on the K-Bodys. I found the 40" on sale at Sears for $29, went to HD and they gave me another 10% off. Bought 6 40" for $26 ea. The lesson hear is keep your eye out for the sales.
TDF
Do you have an adjustment on that machine for height of the out feed table relative to the cutterhead. If they aren't in the exact same plane, your cut will be slightly convex or concave. When you set the adjustment, check it against all the cutter knives, not just one, to ensure you are not setting to a low or high blade. A few thousandths of an inch makes a difference. Same problem will occur unless the tables are exactly parallel.
That being said, Joe is right. Many work to get just that kind of fit
Dick, to my knowledge there is no adjustment of the outfeed table. it is fixed. for those of you familiar with this machine, the knives have height adjustments but in order to do it you set the knife height release the blade holder mechanism turn the blade holder a little to get to the set screws to tighten the blades and pray that things don't move as you tighten it up, which they inevitably do.
I have noticed that at the outboard side of the infeed table it is a hair lower than the inboard side. in other words the dang tables aren't exactly true. I don't know of any way to fix that. I don't know if the raise lower mechanism is bent or the table itself is out of whack. anyway like I mentioned earlier I finally got the dumb thing set and don't plan on messinn with it for awhile.Steve
I believe my sister has the exact same jointer as you do...
As I was setting it up for her, I noticed that the infeed table was not true while making a very shallow cut (1/64"). However, when making a little bit deeper cut, say 1/32 to 1/16, the table were more true...not absolutely perfect...but true enough. I was measuring all of this with a machinist straight edge, and found that the infeed (outboard end) was almost .030 low on the shallow cut, yet was within .002-.003 on the deeper cuts.
Hope this helps.
-Del
