HEllo. When doing a carving, what is the best way and tool choices one could use to waste away the background in small spaces, especially wasting intno tight, acute angles? Thanks.
Dear Adamstr,
Thank you for your question.
I am forwarding the post to Gary Rogowski.
In the meantime, here is a link to an article that may help you:
http://www.taunton.com/finewoodworking/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=30248
There are several articles at the end of this piece that may give you further information.
Sincerely,
Gerald
Hi,
Well relief cuts will depend upon the shapes you're carving. I use a #1 skew for a lot of relief work, but then I'll find a little bit of curve to my tool will help so I'll grab a narrow #3. When that's too much curve, then I go get my 12mm #2. It just depends on the carving, depends on the kinds of undercutting or wasting you want to do. Sometimes a spoon gouge will get into the tight spots better.
If you had a hundred carving tools, I guarantee that you'd find a spot where you'd need another. Buy the best, keep them sharp, good luck.
Gary Rogowski
http://www.northwestwoodworking.com
