I’m about to try my hand at carving; mostly things like trifid and ball-and-claw feet, maybe a shell now and then. My question is this: what carving tools should I buy to get started? Taunton’s book “Shaping Wood” says I’ll need “little more than a dozen gouges of various sizes and sweeps” but doesn’t give me a clue as which gouges these might be!
Mac
For gouges I would recomend
#3- 8mm & 12 or 16mm
#5- 10 & 16 mm
#6- 8mm & 12mm
#8- 12mm
#9- 8-12mm
8mm or 10mm v tool
10mm skew chisel
back bent gouges 10mm & 12mm #6 & #8
also vieners #11 2mm-6mm
These are the tools I most often use for Newport Shell's and Ball& Claw etc.
The back bent gouges are very usefull. To view fullsize profiles go to http://www.stubaidirect.com or call 1-888-901-8099 talk to Chris or Mark and tell them Dale from Wisconsin sent you. Flexcut also makes a great tool try http://www.flexcut.com Be prepared to spend a few bucks lower quality tools will just cause frusration.
Goodluck
If you have anymore questions E mail me [email protected]
Thanks for the info. Your advise on quality tools is almost the golden rule with me. If I'm going to spend my time in the shop, I want to have fun and end up with something worthwhile. I'll hold on to your address if, make that when, I have more questions.
Good luck with your future carvings. As the previous post mentioned Phil Lowe has a tape to help you learn how to carve a ball & claw foot, this is well done. Taunton also has a tape titled carving techniques and projects which covers a scalloped shell. Nora Hall has a newer tape in which she carves a newport shell, there is also a plaster cast availible for a study aid http://www.norahall.com . A nice study aid for a ball & claw foot is a actual leg by Classic Designs by Matthew Burak at http://www.tablelegs.com You can pick up a single leg for about $30 or $40 and get an idea of proportion. Carving is a great skill to learn and can be incorporated in many styles of furniture other than 18th century. It's also addictive, youll see what I mean when you buy your first set of tools and start carving.
Good Luck
Dale
If you go to Nora Hall's website (norahall.com) she gives a good suggestion for an essential carving kit. Here they are:
#3 (12mm)
#5 (6mm)
#7 (16mm)
#9 (12mm)
#11 (3mm)
#41 (10mm) V-Tool
#56 (16mm) Fishtail
With additional tools:
#3 (4mm)
#7 (20mm)
#11 (6mm)
#24 (6mm) Spoon
#3 (20mm)
I just finished a class on Carving a Ball and Claw Foot from Phil Lowe. Phil has a video out that tells which tools you use. Here's the carving tool list from the class:
* straight chisel 8mm
* straight gouge #5 12mm
* straight gouge #5 20mm
* straight gouge #7 10mm
* straight gouge #8 10mm
* back bent gouge #25 10mm
* spoon gouge #9 10mm
* carvers mallet
The back bent and the spoon would not be considered part of a basic set, but if you're going to carve a ball and claw foot you must have them.
What brands should you buy? Good tools are going to cost you between $25 and $35 each. Bigger sizes or unusual shapes can cost even more. As to brands, everyone has an opinion. I think the best tools are the old (pre-WWII) Shiefield and London tools: Addis, Herring, Ward & Paine, Spear&Jackson, Rbt. Sorby, and others. The problem is they are hard to find in the sizes you need.
Today, about the only good English maker is Ashley Isles -- my favorite contemporary maker. Daustra (Germany), Stubi (Austria), and Pfiel (Swiss) are also good and have a larger selection of sizes, sweeps, and bends.
Nora has a toll-free number last time I checked. Call her and see if she has any Chinese tools left. These are hand-made by a guy and his son in China and are a really good buy and very good steel. Tell her Brandon sent you. You should also buy her videos, she is the best European-style carving teacher around. Also get Phil's video if you want to try your hand at Ball and Claw.
Brandon Ford, Lincoln City, OR
Thanks for the reply. The video sounds like a good place to start before I make a pile of fire wood and learn some new four-letter words! I'll check them out.
