Any suggestions on a good method to center drawer fronts which will overlap the openings where drawers reside on the desk I’m building. The problem as I see it is how to fix the front in the proper position and then extend the drawer so the face can be secured by screws from the inside. Thanks much
Start by drilling the holes for the drawer pulls. Then center the drawer front where you want it. Using the holes, attach the drawer front to the box behind, using screws. From there it will be easy to attach the front from the inside. The last thing to do is to remove the drawer front, attach the pull you want, and reinstall the front with the screw hole you just made.
Why didn't I think of that! Thanks a lot
