How can I best protect my wood floor from wooden dining room chair legs? Presently we use the heavy, stick-on felt pads but they tend to slide off.
Try rubber pads that a brad in them to hold them in the legs.
Otherwise, very fine sand the feet and chamfer (relieve) the edges and very fine sand the edges. Relieving the edges removes any sharp angles that can scratch the floor. Since the legs will flex when pressure is put on the chair, the sharp edges are working against the floor. Fine sand and wax the feet often to remove accumulated grit from the floor. The grit also cause fine scratches in the floor. Even the pads will accumulate grit over time so you want to inspect and clean them to for wear. If the chair legs are angled, the pads will also wear on the edges so they will need to be replaced every so often.
Nylon pads with nails to hold them are available but nylon will scratch as well. BTW, if you are using furniture with casters on solid or engineered hardwood floors, make sure the casters are rubber and not plastic (nylon): anything but rubber can ruin a hardwood floor. Most casters are nylon/plastic since they are cheap. Solid rubber casters can cost upward of $10 each.
Edited 10/31/2009 11:30 am ET by DougGF
Have you seen the plastic cup/felt pad combo (sounds like some kind of fast food and about the same nutritional value :-).The cups are fixed by one small nail and the pad fits inside.Feltac market them through bigbox stores
Sounds like just the ticket. I'm having trouble finding it available. Do you have a link that I could go to?
Lowes have some made by Armstrong for $1.55 for 4
JFRAN,
Go to http://www.leevalley.com and look at 93k85.21. They have two sizes. These serve as grippers to prevent the chair sliding and 93k85.20 lets the chair slide. Both protect the floor just fine, and they stay on.
Hope this helps.
Steve
There are two secrets to keeping one's wife happy.
1. Let her think she's having her own way.
2. Let her have her own way. President Lyndon Baines Johnson
Want to protect wooden floor from chair leg's scratches. Try this-
Surface protection tape
wood floor protectors
Safeglide felt floor protectors. You tap them into the bottom of the chair legs. I just installed hardwood flooring in my house and put safeglides on all chairs and furniture that gets moved a lot. Easy to install...just tap in with a hammer.
Try to use any of below to protect wooden floors from chair leg's scratches...
Felt
Cork
Rubber pads
Carpet tape
