Advise on sureing up some chairs from eastern Butcher Block. What type of glue and what can be used if the fitting are no longer tight?
thanks in advance KaiserRoo
It may depend on what you want to do in the future. I would think hide glue would hold the chair together just fine and can be reveresed in the future if need be. If you don't think it will ever need to come apart at a later time, you could go with any of the pva type glues (titebond I, II or III for example).
Thanks for the advice. Is there some type of mesh that can be used with chair repairs?
KaiserRoo
It's depends on which part of chair is repaired.
KaiserRoo
