I want to make 8 chairs from Honduras mahogany, and I don’t know how to scoop out the contour for the seat. Can it be done with a router and sander? Your experience will help me a lot. Thanks
I use an Arbortech blade on a 4 1/2" right angle grinder. I use the model with just three big carbide teeth. Arbortech sells it with a safety cover, which only gets in the way, and I don't use it. I can rough out a seat blank in five minutes. Then I go to sanding discs on the same grinder, progressing from 80 grit to 180. Then I generally switch to a random-orbit sander for final polishing.
Jamie's approach sounds good.
and www.flairwoodwork.spaces.live.com)
Look for info on Sam Maloof's method using the band saw.
Although power carvers are faster, the inshave is the traditional tool for the job.
http://www.leevalley.com/wood/page.aspx?c=2&p=31069&cat=1,130,43332
For finer work, there's the scorp.
http://www.woodcraft.com/Product/2001825/1305/PFEIL-Swiss-Made-Scorp--PFEIL--Swiss-Made.aspx
A power grinder is a choice. Free-hand work with an angle grinder fitted with the chain cutter is an aggressive tool. Be careful.
If you can secure the angle grinder in a stable holding device and move the piece being scooped out you will have a safe method and one that is easier to control.
Putting a deep gauge in a slab of expensive wood will hurt.
dan
Edited 11/9/2009 5:17 am ET by danmart
http://www.youtube.com/watch?v=g6DaDGE_FJI
Scorp and chairmakers plane (concave bottom) curved scraper . discover the joy of handtools!
That's outstanding! I love and use hand tools, but I don't want to take forever and ever to hog out wood.
Denny
That was a video worth watching. I have a couple of more projects to complete and then I can hopefully get started on the rocking chair. That is definitely an easier way of forming the seat than I had planned.Thanks for posting that.Jim
