Changing Bearings in Router Bits
![](https://secure.gravatar.com/avatar/23feca29989ddeedba62aaf9800bf0c7?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I am thinking of forming a table edge using various bits and would like the flexibility of controlling what part of the profile will be cutting. I was thinking that adjusting the depth and using different size bearings (from a router bit bearing set) would accomplish this. Anyone have any experience with this approach? Any advice?
Maybe practice on the router table? No bearings required there. If you find the winning combination of cutter & depth settings, you can/may extrapolate to bearing/cutter combos. Appreciate there are a lot of bearings, but they are arbor and cutter sensitive. A bearing in one setting may not fit another.
Routs
I wasn't aware that the bearings weren't standardized among the router bits, so thank you. They are just listed with ID and OD. Besides matching the ID, what else do I need to check for when I put a different bearing in the bit?
The ID needs to match, but the 'thickness' of the bearing could be an issue. In other words, on a thinner bearing, you may need to add a washer or two to make up the difference, but in some cases that might not work.
Hopefully, where you shop you can take your bit in with you and get the proper set-up from a knowledgeable salesperson BEFORE you make a purchase. (wishful thinking)
Woodcraft offers a set of router bit bearings for just this purpose. The set contains bearings with inside diameters of 3/16", 1/4", 1/2" and 3/4". Style #145725.
Jim
There are some Freud router bits that can be used with some Freud bearings other than the ones provided. Please contact Freud through the freudtools.com website or email me about the combination(s) you wish to use before attempting.
Freud America, Inc.
As long as the bearings fit, you can use different diameters to get different profiles.
I have a couple of round-over bits that I can use to get a simple roundover, beaded, or double beaded profile depending on which bearing I use, and the height of the bit.
