cheap source for lead or alternative to weight bottom of bookends?
I’m making some bookends and was going to drill out the bottoms and weight them down with lead pellets. Much to my surprise, lead isn’t cheap for this purpose. Anyone know of a cheap source of lead pellets or similarly weighted material for bookends?
thanks for the help.
Scott
source of lead weight
Some stores that sell guns also sell lead shot of various sizes
lead shot
You might try checking shotgun ranges in your area. Some make an effort to reclaim shot from the fall zones of the various stations for use by reloaders. Or, if they have a maintenance day when the range is closed to shooting, they might let you reclaim some yourself.
Otherwise, a reloading supply, like Midway USA, is a possible source - about $43 for 25 pounds.
http://www.midwayusa.com/product/2376134688/lawrence-magnum-lead-shot-8
lead alternative
I had to add some weight to the back of a pair of nightstands I built to keep the open drawer from tipping a shallow table. I used 1/2 dia steel rods from the home center . A 2 1/2" long peice was 2 ounces. A 36 inch rod was about $7 I ended up using 18 pieces per table to make sure the open drawer with contents did not tip the table. The tables were built for a specfic height width and depth of available space. Easy to install, I just drilled a hole with a dowel jig and cut the steel rod with a sawzall.
tire balancing lead?
The classic answer is to get used tire balancing inserts which are made form lead. How one does that has always been a mystery to me.
used tire weights?
I would go to a tire store and ask for weights which are too damaged to be reused. Then you have to either melt them and deal with the fumes or pound them into a shape to fit your project.
lead is not the best
thing to be lying around the house. I think that it has been banned from household items and paint material for health reasons, has it not.
ron
True, there are potential health concerns (real or perceived) with lead. As such, gold might be a safer alternative. ;-)
go for it
the gold!
ron
I'd avoid using lead because of the perceived health hazard. How about bb's cast in epoxy?
I got a couple of bags of lead shot, the kind reloaders use for reloading shot shells, at a sporting goods store just because I got tired of opening up a perfectly good shotgun shell when I needed some shot for weight. They were so handy for holding things down and putting pressure on certain kinds of glue ups that the next time I needed some shot I didn't want to open up one of the bags I was using for weight. So I got a third bag just for the lead and kept the first two for handy weights.
Sand is cheap and kinda heavy, would that work? I have a lathe bench with a hollow cross beam that I filled with sand and you can't lift the thing up off the floor. It kills vibration.
You can find lead at outdoor pistol ranges by digging in the berms. Indoor ranges recycle lead and brass though, and get paid for it.
sinkers and split shot
Depending upon how much lead you need, you can buy lead pyramid sinkers which run pretty large and/or split shot (fishing gear). Then you melt them down.
Melting lead is really very safe and simple. I have a 160,000 BTU (overkill) propane burner (which I use for steam bending). When I need to cast lead for things lik chip log chips, I fire that burner up outside, put the lead in a coffee can or small can with a spout bent in it, and melt the lead. Pick up the can with pliers and pour it into the mold. Doing it outside solves the lead fumes issue.
