Cheap (uhh, inexpensive) moisture meters
I’m going to go for a cheap moisture meter for now, around $35-$40. Anyone have any experience with these? Links follow:
There’s one from Penn State.
A CenTech from Harbor Freight.
Woodcraft’s model
Did I miss any?? TIA.
Another proud member of the “I Rocked With ToolDoc Club” …. :>)
FG-
I'm in the market for a moisture meter as well, but the one's I've seen locally are more than I can justify for my usage. The PSI looks good, it is the only one that goes down to 6%. From what I've read/been told you want one that will read accurately between 6&12%.
Hi Craig. I'm kinda where you're at -- can't justify a real expensive one. I know which one I'd get if I had $150-$200 to spend, LOL, but would rather have a dust collection system.
I tend to lean toward Penn State, but am curious about the CenTech because it has a switch for two different moisture ranges, and I wonder if that gives it a little more accuracy for a "cheap" model.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
American Woodworker did a review on MM's a couple of years back. They also put in plans to build a kiln. The kiln was on the cover. I used the idea to build one as a workbench in my garage. The review was real good and I bought the Timber Check Moisture Meter. http://www.leevalley.com/wood/page.asp?SID=&page=32548&category=1%2C43513%2C45788&ccurrency=2
They had another digital one that I would have bought but the company had a minumum order and if I ever needed new pins, which I definately would have, I would have had to purchase a few hundred to complete the minumum order. Hope this helps?
Hi tony. The Timbercheck always looked like a pretty nice meter to me. If I get cold feet on getting a really inexpensive one, I'd probably get either the Timbercheck, the Delmhorst J-Lite (which you can add accessories to) or the MiniLigno. Hopefully, though, I can get a cheapie one that'll do the minimal stuff needed right now, get the darned DC purchase out of the way, and in a year or two when the wood really starts getting seasoned, go ahead and get my dream-meter.
Is that Timbercheck as sturdy as they say it is? forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Yes it seems to be so far, however I havent stepped on mine and keep it in a cabinet inside the carboard tube it came in. When I spend money the tools have to last awhile.
We already have enough youth, how about a fountain of smarts.
"When I spend money the tools have to last awhile. " No kidding. I get alot of flack for locking mine up and being stingy with them, but not everyone in the family treasures them the way I do, LOL!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
The penn State looks like the best buy for the money. i can't speak for the Harbot Freight one but I bought the one from woodcraft and boy am I sorry. It is made for refurbishing houses rather than woodworking. It only goes down to 12%. Something they neglected to mention in the catalog or I just missed it.
Hi Joe, thanks for posting. Is your MT the one with the pins at the end of a cord?? I was starting to lean toward that one because I wouldn't have to stick head clear into the wood rack when checking the meter, LOL. However, I do see that according to the catalog it goes down to 10% only. Other than the abbreviated range, how do you like it?
Of course, being in the Great Northwest, it's unlikely I'll see much wood below 10%, right?forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
FG,
I've been reading your post and racking my brain trying to remember the research/conclusions I came up with either one or two years ago on this subject. There was a couple of comparative studies, however they did not include any of the models you're considering but the Timberchek was in one study. Both studies, as I recall, indicated they all work well but did little to differentiate the rational for the price difference.
The kicker was that Sarge and a few others came on and indicated they had two units...for different purposes (non-construction purposes) and that is the part I can't remember. At any rate, that is where I got a bit distracted and bought the miter guage...lol
Ooooo, BG, be gentle with that brain.... I have the mags with reviews, and they helped me decide what I'd buy in the $200 range, but then I decided to go cheap. No help with that one.
Yes, there are meters for different uses out there. I'm hoping I don't need one for drywall, though, LOL.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Forestgirl - I've used the Timbercheck for over a year now, dropped it several times and left it outside in the rain once!! - Seems to work just as good as when new, it comes with a spare set of pins and a handy little chart comparing different timbers. The only negative I can tell you is that sometimes the range is 'two' clicks of the rotary switch, instead of one. When this happens I usually do the test again in a different place and all is fine. Hope that helps.
I bought the Penn State moisture meter, works well for the price. Checked it against a friends expensive one, off by 3% on several hardwoods. The drier the wood the more accurate mine is. Green, air dried oak, cherry and locust came out about 3% too low, if the meter I checked it against is accurate.You do not have to use excessive pressure pushing the pins in, but hold the meter for a couple of seconds to get a more accurate reading. I do not use a moisture meter enough to justify an expensive one. I would buy the Penn State moisture meter again even knowing it is not the most accurate one on the market.When the stock is near 12% or lower the Penn State was within 1% on most boards tested.
mike
Hi MikeK, thanks muchly for the first-hand report on the PSI meter. So, if I read you right, if the meter reads 12%, the wood is probably 12% or 13%. Probably close enough for me right now, LOL. I wish I knew someone with a good meter, but I'm the only one in my circle who even thinks of using one at this point.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
