I just recently built a cherry entertainment cabinet and dyed it with an aniline dye to even out the color. The dyes caused the wood to take on a broader color contrast, giving it a somewhat figured look. Is this OK? Should I have sealed the wood first and cut down on the absorption of the more open grain, or is this a desired effect? Need some opinions here.
Carl
This is a case of beauty being inthe eye of the beholder. The question of whether this is OK or not is one that can only be answered by you (or your customer. It's a matter of taste.
Bob
*Cherry will absorb dyes and stains unevenly (blotch) if allowed. Brushing or wiping on dyes and stains allows different areas to absorb differing amounts of color (blotch); spraying gives all areas the same amount of color. You might find some good information in the forum at http://www.homesteadfinishing.com
