I’m an extremely new woodworker, so bear with me here.
I’ve got a project I’m doing in cherry, that I’m trying to make sure I know how to stain and finish before I start building it.
I was planning on using a clear Danish oil on the cherry, which is sanded to 220, as a sealer. After the oil dries, I would use a few coats of blond shellac.
I’ve tried this on a test piece, and it looks great. The problem I have is that the cherry I’m using is not completely pink. Some of the cherry changes from pink to a very light, almost white color. I’ve applied Danish oil to a test piece, and it definitely does not even out the two colorations of the wood.
If I use a dark gel stain, will that do a better job of masking the color difference? Or is there another way I could go about this?
Chris
Cherry will naturally darken with age. However, cherry sapwood will never ever darken and from your description of the wood it appears that some of it is sapwood.
A gel stain can give a more uniform appearance for a while but the heartwood will darken and some time down the road you will have a mismatch.
Unless you like the sapwood for contrast or as a design feature you could consider cutting it out.
*Chris,You might want to click here: "Cherry Blotching?" for another opinion. Personally, I have yet to find a light colored wood that doesn't darken with age, eventually.Dano
