I just finished a cherry chest. Finished it with Watco and wax. The Watco really brought out the grain, but there is a fair amount of “blotchyness” typical of cherry.
I have heard of using a coat of shellac under stain to reduce the blotchy look. Would this work under Watco or BLO?
Thanks.
Paul
You are referring to what's generically known as a "washcoat." Your report is why I keep pounding the "Practice before you touch the workpiece" drum. A washcoat can be made with thinner and varnish or other finishes also. I've only used shellac, so am not familiar with other approaches.
A washcoat of de-waxed shellac can be used under most (if not all?) finishes. Click here for a description of the Zinsser Bulls Eye Seal Coat by Michael Dresdner. It is a great product, with a long shelf life. You need to thin it for use as a wash coat, and the thinning chart is printed on the can.
Jeff Jewitt has an excellent section on the options for finishing cherry in his book Great Wood Finishes.
Hello, Sometimes the blotches are from not sufficiently closing the grain prior to finishing.-C
Hi Got,
I've reduced the blotchy appearance by using a 1/1 mix of BLO/Naphtha for a couple of coats. Previously, I was using a Danish oil type mix with BLO/Poly/Thinner -- seems like the poly would begin sealing like it's supposed to do, therefore oil from subsequent coats couldn't soak in as deep as they needed to smoothe the appearance. Here in Florida, I have the luxury of doing the oil wipes in the Sun so both the workpiece surface and oil are warm. In cooler areas, you can thin the oil a bit more and/or warm it for better penetration.
Bill Arnold - Custom Woodcrafting
Member of Mensa and Florida West Coast Woodworkers Club
Click Here if you're interested in a good, inexpensive website host.
