I have some cherry tree trunks, that have been dry for over 6 months. What is the proper way to treat the ends from spliting?
too late!
Is it just me or have I noticed quite a few posts from people who seem to think that logs are dried prior to milling?
Napie,
I don't know that it's more common, just that I have seemed to note that some find out about checking after the log is sawn down and lay's around for a while..
If they already have checking, then cut some off each end until the checking is gone. Seal the ends as quickly as possible (always) with anchor seal, or any heavy latex paint. Cherry doesn't need any drying time before milling, so you should always mill it right away, and seal the end grain.
Frenchy, great advice (not!). Always trying to be helpful, you are.
JeffHeath,
You are correct. I should have mentioned the option of cutting off the ends. That may make the log 7 feet which makes 7 foot boards but I suppose they would be better than nothing.
It's too late to worry about that. If you plan to use it for furniture lumber, it should be immediately milled into boards which should be stickered and stacked. It will not dry properly if it is left in tree form.
