I’m looking for a catch typically used on cedar chest that catches when the lid is closed and can be opened by pushing a button. This button also can be locked. I can find lid catches which must be locked and/or opened with a key but can’t find the style I’m looking for. (Looked in Rockler, Woodcraft, Van Dyke’s). I’m using this on a small desk/table that I’m building in which the lid can be opened for quick storage of pens, pencils etc. I want the lid secure but easily opened, e.g. push the button.
George
Try Woodcraft, Rockler etc. They all have them.
Midwood ,If you can't find exactly what you want, use a touch latch
These are used on secret doors or panels that don't show any hardware.
It is attached with just screws and when closed, it latches in place a slight push to further close the door/panel makes the door pop open. The better manufacturer is called Glynn Johnson another good name is Ives'
Google up pushlatches touch latches or secret latches Steinmetz
Steinmetz
Edited 9/1/2004 10:00 pm ET by steinmetz
Thanks for the input. The ones you suggest would work on vertical doors but since this is a lid for a library desk, i.e. horizontal, and would have pressure on it, I'm not sure how it would stay latched. I will, however, look at these and see if its a fit.
Midwood
Mid,These are rugged latches and employ strong springs .
There are available by the same manufacturer , Auxialiary' Pushers' for just your application. Steinmetz
Edited 9/3/2004 10:05 pm ET by steinmetz
Edited 9/3/2004 10:12 pm ET by steinmetz
