My old Porter Cable random orbit sander started to make wierd noizes and I decided to get rid of it before it flew apart in my hands. So now’s the time to buy a new one. In researching about this tool I first checked out Consumer Reports and then went to the Amazon website to look at consumer responses to each of the tools Consumers recommended. (caftsman 27957, DeWalt DW423K, Makita BO5012K, Ryobi RS241 their “best buy”, and Porter Cable 333-333VS in that order) The consumer’s reviews were most confusing. There wasn’t one tool that received consistantly good reviews. I read one review that I got off of Google that praised the P/C, Consumer Report’s second of last choice as the best random orbit sander on the market. I would like to get a good tool, but not in the Fein or Festool price range. I know that this isn’t a world shaking decision, but I would like to make a reasonably good choice. I also know that there are a lot of experienced woodworkers on this site whose advice I respect. Thanks in advance for any suggestions you might have. Shalom
I have two RO sanders and just bought a third. The two I have are an older Bosch 3107, which is a 5" model. It is a nice sander and fairly aggressive, tends to leave swirl marks on the wood. The other one is a Ridgid 5" model that is a palm-grip (the Bosch isn't), I got that one because I needed a second one for another person to use at the same time, it was very slightly used and cheap at a local used-tool store, and had gotten some excellent reviews. I have bought the P-C 333VS as a gift for a couple different people and they like it.
The one I just bought and am waiting for to arrive, is a Bosch 1250DEVS, their "flagship" 6" orbital - similar to the Festo and Fein 6" models. I needed an aggressive sander for edging on hardwood floors and didn't need a dedicated floor edge sander. I will probably get rid of the old Bosch if this one works the way it's supposed to.
If you're only looking for a smaller 5" palm-grip then go with the Porter-Cable 333VS or the Ridgid. Neither one is a dog.
Fine woodworking did a test recently, the bosch was top choice in finish quality.
I purchased a bosch 5" for finer sanding and the porter cable 6"ros for the bulk sanding. At the time I looked at the festool 6" and hand extreme sticker shock. Now a year later... I wish I had bought the Festool. The PC has vibrated apart many times and does not produce a fine surface,. The bosch just is too small to get the job done quickly, but sands a very fine surface. When I reciently bought a festool router, the salesman demonstrated the sander to me. He took a rough sawn board and sanded it to a smooth perfect surface in moments. Next time the Porter Cable falls apart... it will be replaced.
If you don't want to spring for a Festool sander, I can testify to the virtues of the Makita.
This one with a handle:
http://www.makita.com/menu.php?pg=product_det&tag=BO5021K
And its sister sander without the handle:
http://www.makita.com/menu.php?pg=product_det&tag=BO5010K
I have both, along with some Festools, and the Makitas compare very favorably in terms of ergonomics, vibration, and overall effectiveness.
The dust collection bags work very well -- not as good as the Festool with a vac attached, but you're still not going to create a cloud of dust.
I have a flock of other sanders, and the Makitas are my favorite.
John Wooden 1910-
Being unconvinced of any advantage to random orbit, I just purchased a Bosch 1/2-sheet orbital sander. I can't testify to its durability, but I could not be more satisfied with its performance. It doesn't vibrate, collects dust very well, uses ordinary sandpaper sheets, & comes equipped with paper hole punch & sawdust collector/filter. The collector provided me with nice sawdust for making my own pore filler.
Cadiddlehopper
The Makita 5" ROS (I think 5010 or some such number, several years old design) has had a lot of positive responses. I had a DeWalt 5" ROS and it was just OK. FWW recently had a review and the Bosch 1295 came out on top (it was introduced this year). They did a test to see how much wood it removed and it was the best of the bunch w/ vibration and swirl patterns factored in. I can attest to it being a great 5" ROS. I've used it a lot recently and I really like it. A huge factor with any ROS is the dust collection. I bought an adaptor to hook it up to my Fein vacuum. Definitely the way to go. You will find that if you don't hook it up to dust collection, a lot of dust is left on the wood and it won't be nearly as aggressive (any sander) as you are sanding wooddust, instead of a fresh surface.
I bought the Festool 150 FEQ for larger surfaces as it has two modes. I still have a Metabo 450 dual mode 6" which was also made in Germany, but I'm selling it as I thought the Festool was better (and I don't need two!). The Metabo is also being sold at HD as a re-badged Rigid, however, these ones are made in China.
Rod
Edited 11/2/2006 12:38 pm ET by RodWolfy
Edited 11/2/2006 12:39 pm ET by RodWolfy
Rod,
Let me second the Mikita 5010 I have tried several (most and it's the quietest least vibration does the smoothest and fastest job. I won two of them and they have taken most of my 35,000 bd.ft. of hardwoods down in steps to 220.
S, I have a pc 333 vs and looked for a 6" and some folks here spoke of a Ridgid #2610 made by Metabo in Germany for $129 at Home Despot . It"s a killer, good weight, dual orbit, dust collection and speed select. It's the OLD model so look for it, the new one is the #2611 made in China and a dog. The home dopy folks don't care so root it out if it's there. Good luck, Pat
Pat,
I've got the same PC3333 model you have and I also have the Ridgid 5" ROS - I really like them both. I usually use the PC333 for smaller type jobs and use the Ridgid for table top work etc. as it is a bit heavier than the PC.
RickRick in Cowichan Bay, B.C. - 50km north of Victoria, B.C.
My Website: http://www.rickswoodworking.ca
I have the new Bosch 5" and I am quite pleased with it. Very little vibration, quiet and captures a good deal of the dust. The rigid dust container takes a while to get used to but it works very well and e,pties easily enough.
I've been through a number of sanders in my time and whenit comes to 5 inch ROS I use a Festool in the shop and PC333 in the field. When I've taken the Festool out in the field i end up getting other guys wanting to try it. The PC 333's last between 2 and 4 years for me, depending on how often I remember to blow tham out with compressed air.
Now that B&D has purchased PC I don't know if I'll stick with them. I've been through 5 or 6 DeWalt 5 inch ROS and they haven't held up as well, for me at the PC. I tried the Ridgid, but got the one made in China and it ground itself to death in less than one year. I didn't know that some were made in Germany, maybe I will try them again if I can find one that says it was made in Germany. Bosch has worked for me, but they were/are more expensive that the PC and I didn't get any more service from them, they did feel better.
If you are looking at a 6 inch ROS then Festool or Bosch seem to be the favorites. I have an 8 inch Fein, and it does a job, but I don't carry it everywhere, it has good dust collection as does the Festool.
Thanks to everyone who responded to my question about a random orbit sander. I finally went with the variable speed Makita. It's light, it doesn't vibrate much, and given the low volume of work I produce,I don't realy mind that it's a little less aggressive than some of the other great models. Perhaps the deciding factor was thar FWW rated it's dust collection highly. I find this forum a blessing. I'm always amazed at woodworkers' willingness to share information. Thanks again. Shalom
