I’m looking for advice on a couple of fronts. I need to make a crib for our outdoor Christmas Nativity scene. After many years, the plastic one succumbed to the weather in south western <!—-><!—-><!—->Ohio <!—-><!—->. The old crib was 20-inches long by 16-inches tall when folded flat and looked somewhat like an “X” when open. I would like the one I make to fold flat or nearly flat too and open into an “X” too (unless anyone knows of plans to make a crib that can be taken apart for storage too or feels like describing a method to build a crib that can knocked down easily).
I plan on the crib being rather “open” to allow the rain and snow to fall through to the ground instead of collecting in the crib. I was planning on using wood slats about one-inch to one and one-half inches wide by about 3/8” or ½” thick and then cutting half-dadoes where the slats cross each other.
Question #1: What would be a good wood to use for this project?
Question#2: What would you to finish and protect the wood?
Question#3: Any idea or suggestions on the type of hardware to use that would allow the crib to fold nearly flat?
Thanks in advance for all your help..
I'd use pressure treated 2X2 railing stock in an X like an army cot, snap on strectchers on either end and fish net for the bed. Carriage bolts for the pivots.
Joe
Thanks for the 2x2 idea and the other suggestions. I had thought of using pressure treated at one time but decided against since I was looking to use thinner stock. I can use the 2x2's and maybe some 1x4' ripped to 1x2 for slats and not use the fishnet.
Edited 10/16/2005 9:20 pm ET by GoRedsUS
